Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Project body curve
2 REPLIES 2
511 Views, 2 Replies
Project body curve
I am trying to use a projection of the rocker surface of a surfboard to machine a groove (or channel) in wood. The resulting sketch has several control points. I would like to extend the curve on either end using a spline and then get rid of the control points. Is there a way to do this? When I try to use the generate a machining path, the milling head jumps forward and backward illogically along the segments of path instead of milling a continuous curve from one end to the other.
2 REPLIES 2
etfrench
Try using the Mesh tools to create continuous spline:
  1. In your sketch with the projected spline and extensions, create a closed boundary with the projected spline and extensions as one side of the boundary.
  2. Extrude this.
  3. Save as stl.
  4. Import the stl.
  5. Create a Mesh Section (Sketch|Mesh|Create Mesh Section).
  6. Fit Curves to Mesh Section.
This should give you a curve with only endpoints.
ETFrench
g-andresen
I have just tried it with one projected and 2 added splines.
Here is the result:
toolpath 3 d paralleltoolpath 3 d parallel
günther
Technology Administrators
