Hello folks,
I'm trying to export this file: https://a360.co/2pGKay9 as a flat pattern. But every time I get this unexpected error message. I fixed the SVG and there ain't a warning review in my timeline. So I'm wondering what the error message means. Hope somebody can help me out!
Cheers,
Rink
The error message is: Error: There was an unexpected problem with exporting the flat pattern as a DXF file.
I'm not using this environment often, so I just can play around. If I scroll back in history one step, everything works find. So the problem must be related to the cutouts.
So, I made another test file with a much more simple SVG. Turns out Fusion can't handle SVG extrude cuts in a sheetmetal body. Anyone that knows a short term solution? Got to deliver this project!
Happy Easter!
Can you File>Export and then Attach a *.3d file here that exhibits this behavior?
How do you propose to manufacture these features (representative sample - I did not check all).
This entire design can be done much more easily.
Only one (contoured) Flange needed.
Extrude 1,2, 3 and 4 not needed.
Flange 2 and 3 not needed.
No Moves needed.
There is a much much much easier technique for placing the Holes (as one feature) that is easier to edit to boot.
