When I print a dwg from a pdf file the lines are so much more defined. When I print from the fusion program they are much weaker. In the model and in the title block it seems the lines are just weak when printing in the program vs PDF. Is there a setting I'm missing?
Solved by segallyscott. Go to Solution.
I figured it out. In the document settings i can change the line width and in the print settings i can activate line widths.
Be sure and check the indicated box, it will make a world of difference in the line quality and darkness.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
