Line Definition When Printing From Program vs. PDF
2 REPLIES 2
segallyscott
196 Views, 2 Replies
When I print a dwg from a pdf file the lines are so much more defined. When I print from the fusion program they are much weaker. In the model and in the title block it seems the lines are just weak when printing in the program vs PDF. Is there a setting I'm missing?
2 REPLIES 2
segallyscott
in reply to: segallyscott
I figured it out.  In the document settings i can change the line width and in the print settings i can activate line widths.
jhackney1972
Be sure and check the indicated box, it will make a world of difference in the line quality and darkness.
John Hackney, Retired
