We are attempting to make the transition from autocad lt to Fusion 360 since we are becoming more focused on 3D modeling. In Autocad LT we have created several Layout tabs with ready to print A11 drawings. Once the file is imported to Fusion 360, I am unable to locate these layout tabs. I am aware of how to create new ones through Fusion Drawings but, where have the existing ones ended up?
Thank you for your help in advanced!
Is is possible to attach the AutoCAD drawing containing the Layout Tabs? If not, can you attach another AutoCAD drawing with similar layout tabs? You will find the Attachments section below in a reply post. If the DWG file refuses to attach, zip it first.
John Hackney, Retired
Only Modelspace entities are imported into Fusion 360. You will have use the Export Layout to Model command and then save the DWG to open into Fusion 360. Also note that there are objects, contained in AutoCAD drawings that are not supported. I attached a screen capture of some of these.
