I have a sculpted form in .stp form which I have to create a wooden structure inside. I am having trouble using fusion with it as it's very slow and there's thousands of faces. Is there a way to simplify the form so I have shell it and work inside of it ?
I'd post a screencast but Fusion is currently frozen (and probably mad at me )for the third time .
Solved by TrippyLighting. Go to Solution.
Fusiosn 360 does have a function to reduce the faces of a mesh in the Mesh workspace. However, you might be better advised to use Meshmixer for reducing faces. Meshmixer has many more tools specific for dealing with large triangulated meshes.
