Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
incorrect system time error
10 REPLIES 10
Message 1 of 11
6079 Views, 10 Replies
Unable to access Fusion as the error incorrect system time comes at each time.
10 REPLIES 10
Message 2 of 11
sakolkar
I am really sorry you are experiencing this issue. Could you please confirm that both your system time and time zone set as expected? Also, is your system set up to synch its time with any particular time server?
Saurabh Akolkar
Autodesk, Inc.
Message 3 of 11
in reply to: sakolkar
Cheers
Philip
Sent from my iPhone 6S+
Message 4 of 11
James.Youmatz
Hi @Anonymous,
Just to confirm - is this issue taken care of now or are you still having the date/time error? If so, try switching it off to a new automatic time zone, and then switching it back and saving it. The resync should work at that point.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
Message 5 of 11
in reply to: James.Youmatz
Good morning James,
I have tried everything : changed time zone and changed back to Pacific time zone then Baja California then back Pacific Mountain time zone etc. with always the same error result as shown in previous screen shot posted 🙂
I have also changed the time server back and forth with at each time tried to open ADSK 360 but always same error result..
Finally I have deactivated the automatic time with internet server but same problem always same error displayed...
Hope this info helps
Sincerely yours
Philip
Message 6 of 11
James.Youmatz
Hi @Anonymous,
Can you email me at james.youmatz@autodesk.com? I'd like to take a closer look at your system if you have a chance today.  Then we can report our findings back to the forum once we have a solution.
Before we do that however, can you confirm that you tried the solutions in the following article found here.
James Youmatz
Message 7 of 11
brad
I am having the same problem right now
Message 8 of 11
in reply to: brad
In another post I explained procedure
1/ select manual time setting
2/ correct time
3/ restart computer
4/ re set to internet time
5/ uncheck the Microsoft server
6/ check the other server
Should work , home I remembered the correct procedure
If not reply and I will go check my previous solution reply which worked immediately
Cheers
Philip
Message 9 of 11
brad
on my windows 10 i am unable to set the time manualy and my time is set through my server to the windows server time i am unable to change it
Message 10 of 11
in reply to: brad
Ok let me check as I did it on my Windows 10 Dell machine
I will get back to you this evening
Thank you for your patience
No worries once I get the precise method I used you will be good to go.
Normally the Autodesk Fusion moderator is aware of the technique as had this same issue and had been resolved.
Try check my previous posts but anyways will inform you this evening
Cheers
Philip
Message 11 of 11
innovatenate
in reply to: brad
There a link below that may be useful.
https://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Inc...
The clock cannot be off by even a minute. This is forbidden for security reasons.
I hope this helps.
Nathan Chandler
Principal Specialist
Technology Administrators
