How to save object file with appearance
I just created a table and need to place the solar panel on top (Dark Glass) but when I create that file, by default saved as Physical Material as Steel and appearance as glass. While saving to OBJECT File its turns back to steel and I can see the difference in Obj file.
Please provide a solution o this.
I am attaching the main object file.
Solar Panel and the final output in Obj format.
Thank You
TrippyLighting
No .obj file was attached.
It does not matter anyway. Fusion 360 does not store appearances in .obj files.
Physical properties cannot be exported to .obj files as that format does not support that AFAIK.
So how we can solve this? I need to input this file into an augmented reality software and that software only accepts .obj files. Or I need to check other file options. Is there any other file format (with physhical properties) that will also acceptable to all software?
