Can't figure how to close my sketch so a specific part can be extruded
Hi all!
After doing some exercises and playing with the sketches, I ran into an issue.
In the screenshots attached, you can see that I have started the sketch using circles and then I used the lines to finish drawing the sketch.
As you can see, the only parts that are blue and extrudable are the circle, the center part seems not closed and I can't extrude it.
Any clue on how to fix this ?
Thank you !
Capture d’écran 2020-12-11 à 17.21.30.pngCapture d’écran 2020-12-11 à 17.21.36.png
Thank you
TheCADWhisperer
Your geometry is not properly constrained.
Here you are !  Thanks !
TheCADWhisperer
Start dragging white dots.
What do you observe?
I recommend that you create ONLY one line (or arc or circle) at a time and fully constrain it before going to next line, arc or circle.
Hi @TheCADWhisperer , I guess my first draw was a mess :D.
I have done it from scratch and now it's ok.
Just have to work on how to usefully uses constraints in my sketches !
Thanks !
