Help lofting between two heart shape sketches.
main2839
Observer Observer
main2839
Observer
Observer
I am trying to loft between two similarly shaped heart sketches, but I keep an error regarding "One or more of the profiles have multiple edge loops. Try reselecting the profile."  I tried getting the loft command to work by using rails but was not able to make any progress with that either.  Thank you.
pramod.pk2XX6G
Hi @main2839
Thanks for posting the query in the community.
There are a few self-intersection areas in the profile, which do not allow you to create a loft body.
Take a look at the .f3d file and the attached screenshot.
Pramod
main2839
Observer
Observer
Thank you for your help, how would I identify and fix the self intersection areas in the sketch profile?
pramod.pk2XX6G
Hi @main2839
Thanks for the reply.
When you try to perform the loft feature, Fusion 360 throws an error message " One or more profiles have multiple edge loops". This is a clear indication of the profiles are self-intersecting each other.
Apart from giving the error message, there is nothing special tool for it.
Pramod
TrippyLighting
For this kind of loft, instead of using rails use the Keep Tangent option.
IMHO that should actually be the default!
g-andresen
Maybe an extrude with a taper will do?
günther
