Unable to apply duplicate chamfer on same feature.
c.d.pass
c.d.pass
I am able to create a .03 fillet along the edge of side A, but not on side B. The front pivot bracket was created from a single extrude command so the shape has to be symmetric. Anyone know why fillet can't be created on side B?
Steven_Gao
Not sure where is the side B for the fillet failure. Can you use a picture to show the position?
Steven
laughingcreek
not sure were your talking about either, but at this location you created what's called a non-manifold face.  eats the lunch of must cad systems.  either increase the over lap, or make a clear separation of those faces.
c.d.pass
Sorry for the long time between this reply. Been off the computer for a while.
I created a new photo to better identify the corner where the fillet can't be created.
Corner B accepted the fillet command. Corner A will not accept the fillet command. Gives an error.
As stated before, the shape was extruded from Profile Z.
Steven_Gao
As @ said there is a non-manifold face/edge on the corner of A side. Refer to the attached picture. I tried to add a small piece in here and then added the fillet, after the fillet, removed the small piece again. I know this is a bad modeling experience, but just want to show the issue and workaround in here. Refer to the model for details.
Steven
c.d.pass
Thanks laughingcreek and MingseiGao for solution. Never would have found that root cause on my own.
