Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
glass render problem
11 REPLIES 11
Message 1 of 12
pivetta.n
1002 Views, 11 Replies
pivetta.n
Please see the image attached. I'm not able to render the glass in a proper way. Before the glass was touching the surface and then I moved the glass 1 mm far from the top but same result.
Thanks in advance for the help.
11 REPLIES 11
Message 2 of 12
LeonardoBN
in reply to: pivetta.n
LeonardoBN
Hi @pivetta.n.
Do you have other any duplicated bodies?
Have you set a new Dielectrics Priority Control? There are instructions in the article's last section:
How to create realistic renderings with transparent materials
Leonardo Brunelli do Nascimento
Chemical Engineer
Hi @pivetta.n.
Chemical Engineer
Message 3 of 12
TrippyLighting
TrippyLighting
Can you share your model? (export as .f3d and attach to next post).
Message 4 of 12
pivetta.n
in reply to: TrippyLighting
pivetta.n
Hello  @TrippyLighting
Here attached the file.
thanks for helping.
thanks for helping.
Message 5 of 12
TrippyLighting
TrippyLighting
Instead of moving the entire glass body up 1mm you only moved the top face up 1mm.
If you correct that it'll work 😉
Message 6 of 12
pivetta.n
pivetta.n
Thanks @TrippyLighting,
hanks for helping.
All done for that glass, so I did the same for an other coffee table, but the problem moved. See the images attached: before and after. The glass was touching the top where I have polygons on the top part of the glass and when I lift up the glass of 1 mm now I have the poligons on the edge of the glass.
hanks for helping.
Message 7 of 12
TrippyLighting
TrippyLighting
I need to have access to your update model. Obviously!
Message 8 of 12
pivetta.n
pivetta.n
Sorry @TrippyLighting , here you are.
Thanks again for heping
Message 9 of 12
TrippyLighting
TrippyLighting
Ia m not sure what you did. Either you applied different glass materials to different faces, or you modified one of the existing glass materials (nothing has zero roughness!)
If I use one of the standard Glass materials things work fine.
Message 10 of 12
pivetta.n
pivetta.n
Thanks @TrippyLighting ,
I did what you said. the situation from far looks ok but if a go closer is still the same but it's fine. Thanks a lot for the help, I apreciate it a lot.
Message 11 of 12
jdarthurs
jdarthurs
Same here, exactly.
Same here, exactly.
Message 12 of 12
TrippyLighting
in reply to: jdarthurs
TrippyLighting
Then, as should be obvious if you read my previous replies, please share the model in original .f3d format!
