I know this has been asked in a myriad of different ways by other forum users and on all the RC forums.
Currently, I'm attempting to accomplish this flatten function using meshmixer, but that seems to be going away. AutoDesk states they are incorporating some of the functionality of meshmixer in the Fusion360. Will the "unfold" or flatten feature be in the updates?
I have come across discussions of solutions, in Fusion360, claiming to use the sheet metal function. I have been able to flatten a spline shape by creating a flange on the spline, but have had no success once the sheet metal part is edited for its final shape.
The material is usually lite-ply or balsa.
On a positive note, I've achieved a certain level of success with creating model in fusion!
(The windscreen modeling is for another topic, so don't judge! It is also to be cut from a flat sheet.)
Joe
Solved by jhackney1972. Go to Solution.
@mango.freund as long as it creates a developable surface you can use a spline.
Please attach your model or at least the component you show that needs to be flattened.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
My method is to actually replicate your component into a sheet metal component and then flatten it. The process is outlined in the Screencast. In the attached model, I have turned off the visibility of your component and changed the opacity also. Let me know if you have any questions.
John Hackney
Retired
The reason John is thickening a surface instead of directly converting your part into a sheet metal component is that the way you designed the piece, would not create cut walls perpendicular to the top and bottom surfaces.
Yes, you are correct, they do need to be perpendicular to the top and bottom surfaces. I tried several ways to create tabs and slots to achieve this. The method I used here is about the closest and cleanest. Now to try it on the laser and see how it works.
You are the man John!
I am going to work on this technique in the hopes of replicating what you demonstrated.
Thank you very much!!
Do you have a recommended method for creating the tabs and slots so they are exactly perpendicular, in order to avoid the surface steps?
This is the fuselage side I have been trying to flatten and may have to resort to doing it by hand
That looks like it has some compound curves. I had used meshmixer for those types of surfaces. Now, all the mesh tools are in fusion. I’ve yet to experiment with them.
