Flat pattern view in sheet metal drawing
Hello, this is my first post to the form. I have created a sheet metal bracket and added a flat pattern to the model. When I create a drawing for this part, I have no option of creating a flat view. The "reference", and " "representation" options are greyed out in the "drawing view". I read somewhere that under "representation" I should be able to pick flat pattern. Thanks for any ideas, Dave
TheCADWhisperer
Can you File>Export and then Attach your *.f3d file here that exhibits this behavior when creating the drawing.
Wow thanks for the fast response CADWhisperer. I just realized I created my sheet metal part inside an assembly instead of on its own. I didn't realize it, but now I see the Asy icon at the top of the model tree. I am just learning F360 so I'm making dumb mistakes. I made a quick test sheet metal part, and I see the option for flat view in drawings so I'm set. Sorry to waste your time, but thanks for responding!
kolasanisaikrishna
how come that i cannot create a drawing using "flat pattern reference". i tried to create a drawingScreenshot 2021-07-07 at 9.33.22 PM.png after unfolding the bends and in this case i cannot select the bends "using bends identifier" and create toggles and table @TheCADWhisperer
g-andresen
1. create a flat pattern
2. create a drawing of your flat pattern
Screencast
günther
kolasanisaikrishna
yes that solved it.thanks
