Extrude to surface question
cjkinsman
cjkinsman
I'm looking for some help with extruding up to a surface. I've attached pictures for clarity. I extruded a curved surface as the reference, and am trying to extrude up to this surface. When I extrude up to the surface, I can only extrude up to one surface and the curved corners are left out of the profile. Resulting in the extrusion having square edges. I guess my question is, is there a way to "extrude to surface" like there is in SolidWorks? Sorry for the silly question, I hope you can understand what I'm asking.
Help is much appreciated!
Cheers
Accepted solutions (4)
Rushikesh.kadam
@cjkinsman setting the Extend option to To Adjacent Faces should do the trick.
If my reply was helpful, please click the "Accept as Solution" button. It helps others get the answer quickly! A "Like" is always welcomed.
Rushikesh Kadam
Senior QA Engineer
Quality Assurance
Autodesk, Inc.
cjkinsman
Hi Rushikesh,
Thank you for your help. I expected this to work, but I get a "cannot complete extrusion" error when I try to do it this way. I've attached the fusion file for reference.
Cam
wersy
You also could extrude through the surface and use the surface to cut off the the body.
TrippyLighting
Your extrusion profile falls outside of the "to object" boundary:
jeff_strater
your surface is too small.  You can tell this if you make both the solid and surface visible - you can see a line where the solid body (and therefore the profile) sticks outside of the surface.  That is what is causing your termination to fail.
You could re-design this surface to be a bit bigger.  I got lazy and just offset another surface by 0.05, and that did the trick.
Jeff Strater
Engineering Director
cjkinsman
Thank you very much!
