Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Creating round head bolt
5 REPLIES 5
harishjangrasiit1
1097 Views, 5 Replies
I was trying to create round head bolt. I extruded a square to create a square bolt head but now i have to make it round. I tried fillet but didn't get the results
5 REPLIES 5
Would you be able to share the design?  Also, if it is a standard bolt, you might want to try the McMaster Carr support in Fusion.  Go to Insert > Insert McMaster-Carr component, search for the type and size you need and insert the 3d design.
Best regards,
Sanjay Jayabal.
Sketch a circles, and then extrude cut the area of the edges
Regards
here is the design
My solution: Sketch the profile (half) and revolve it
The image you attached does not depict a Round Head bolt.
In any case, the process is essentially identical.
Technology Administrators
