Creating round head bolt
harishjangrasiit1
harishjangrasiit1
I was trying to create round head bolt. I extruded a square to create a square bolt head but now i have to make it round. I tried fillet but didn't get the results
sanjay_jayabal
Would you be able to share the design?  Also, if it is a standard bolt, you might want to try the McMaster Carr support in Fusion.  Go to Insert > Insert McMaster-Carr component, search for the type and size you need and insert the 3d design.
Best regards,
Sanjay Jayabal.
SaeedHamza
Sketch a circles, and then extrude cut the area of the edges
Regards
Saeed Hamza
harishjangrasiit1
here is the design
lichtzeichenanlage
My solution: Sketch the profile (half) and revolve it
TheCADWhisperer
The image you attached does not depict a Round Head bolt.
In any case, the process is essentially identical.
