Hi All
I'm new to Fusion 360 and modeling in general, so please bear with me...
My "issue" is, I want to make the model below, but I cannot figure out, how I make the correct rounding for the object to fit. I do have the measures for how wide and tall it is, but there needs to be some kind of angle calculation or measurement, but this I cannot figure out - hope someone can help.
This is the model, please notice the "inner" rectangle, it's these roundings I need to get right:
This is the measurements:
This is my model so far in fusion 360 (I've tried numerous kind of things):
I hope you can help
Best regards
EDIT: Added 3D Model file to attachments
It would be easier to help you if you attach your Fusion 360 model to the thread: File|Export|Archive file *.f3d
ETFrench
Thank you for quick response, I've added the .f3d file to original post, hope you can help!
If you have a scanner, then you should be able to get an accurate image which you can import into Fusion 360 as a decal.
If not, draw, then print, a set of arcs that are close to the size. If you print them on tracing paper, you'll be able to match the printed arc with the actual arc.
ETFrench
