Calculate rounding
5 REPLIES 5
nikolajholdt
1208 Views, 5 Replies
Calculate rounding
Hi All
I'm new to Fusion 360 and modeling in general, so please bear with me...
My "issue" is, I want to make the model below, but I cannot figure out, how I make the correct rounding for the object to fit. I do have the measures for how wide and tall it is, but there needs to be some kind of angle calculation or measurement, but this I cannot figure out - hope someone can help.
This is the model, please notice the "inner" rectangle, it's these roundings I need to get right:ModelModel
 This is the measurements:
MeasurementMeasurement
This is my model so far in fusion 360 (I've tried numerous kind of things):
ModelModelI hope you can help
Best regards
EDIT: Added 3D Model file to attachments
Tags (1)
5 REPLIES 5
etfrench
in reply to: nikolajholdt
It would be easier to help you if you attach your Fusion 360 model to the thread: File|Export|Archive file *.f3d
ETFrench
nikolajholdt
in reply to: etfrench
Thank you for quick response, I've added the .f3d file to original post, hope you can help!
nikolajholdt
Bump... Can anyone help?
etfrench
If you have a scanner, then you should be able to get an accurate image which you can import into Fusion 360 as a decal.
If not, draw, then print, a set of arcs that are close to the size. If you print them on tracing paper,  you'll be able to match the printed arc with the actual arc.
ETFrench
etfrench
This may help a little:
There isn't enough information in your first post to do more.
ETFrench
