Message 1 of 10
See video for explanation, I'm not getting all features completely mirrored.
Is it possible that your plane (mirroring line) is not in the center of your object?
Edit: Would be nice if we could get an export of your design or a link to your project.
Try redoing it setting the compute option in the mirror dialog box to optimized
Regards
Saeed Hamza
@SaeedHamza that did it!
Now the question is.... WHY???? Is it a bug? or just really bad design? Why would one option fail to copy only parts of just one feature?
@jeff_strater @James.Youmatz @innovatenate could you help explaining this behavior ?
I can kind of explain: There are several modes available for pattern/mirror, which vary among their performance and success profiles:
My personal approach to mirror/pattern is: I start with the fastest, and work my way up until it works. Sometimes it takes a few iterations, but I'm always able to find an option that works.
Jeff
For sometime now I've been operating under the assumption that pattern faces was the slowest. That was conclusion me an someone from AD (forget who) came up with, when he was helping me on a problematic model. That seems to have been a unique situation, as in other test cases patterning faces does seem to be faster after all. Thanks Jeff, always nice to have some insight on how things work in fusion.
