Button for Sketch.ShowUnderConstrained
christopher_hermansson
Message 1 of 11
Hi! I want to make an add-in that places a button on the sketch toolbar that runs the command Sketch.ShowUnderConstrained when clicked. I've been trying for several hours, with the help of Chat-GPT, with no real success. Is it even possible?
Replies (10)
Message 2 of 11
kandennti
Hi @christopher_hermansson -San.
The following sample switches between Driving/Driven dimensions.
It should be performed in the edit state of the sketch.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        des: fusion.Design = app.activeProduct
        skt: fusion.Sketch = fusion.Sketch.cast(des.activeEditObject)
        if not skt: return
        dim : fusion.SketchDimension = None
        for dim in skt.sketchDimensions:
            dim.isDriving = not dim.isDriving
        ui.messageBox("Done")
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Message 3 of 11
kandennti
Sorry, I made a mistake.
In the following sample, you can toggle the "Show Constraints" on the screen.
import traceback
def run(context):
    try:
        if not skt: return
        skt.areConstraintsShown = not skt.areConstraintsShown
    except:
        if ui:
However, the Sketch Palette check was not linked.
Therefore, I modified it and used the text command.
        # skt.areConstraintsShown = not skt.areConstraintsShown
        txtCmd = u'Commands.SetBool show_constraints {}'.format(
            0 if skt.areConstraintsShown else 1
        app.executeTextCommand(txtCmd)
Message 4 of 11
Thank you, but that wasn't really what I was asking about. There is a text command "Sketch.ShowUnderConstrained" that you can type into the text command prompt. I just want to add a button to the toolbar that executes that command.
Message 5 of 11
kandennti
Sorry, I misunderstood again.
The only way to add a button to the menu is to create an add-in.
We do not use that text command, but we have created an add-in that does something similar.
https://github.com/kantoku-code/Fusion360_SketchToolPlus
There are several commands, but the "SketchAnalysis" command does the same thing.
However, they are all displayed in Japanese. If necessary, we will modify it so that it can be displayed in English as well.
Message 6 of 11
Fantastic!
Message 7 of 11
kandennti
The display has been modified to switch according to the language of preferences.
Some words may not be appropriate due to the use of a translation site.
Please let me know and I will fix it.
Message 8 of 11
Christoph_360
Hello
I think it's a shame that such an important command is not offered in the Sketcher. I had a lot of fun with the Sketcher from the beginning, but I was always afraid of finding a missing Constrain. It was just too much of a relief when I found the command "Sketch.ShowUnderConstrained" in the Forum.
Christoph
Message 9 of 11
toffypops
there is no ZIP file for download at https://github.com/kantoku-code/Fusion360_SketchToolPlus
Message 10 of 11
kandennti
Hi @toffypops -san.
Click on the green “Code” to display.
Enjoy!
Message 11 of 11
MichaelT_123
Kandennti-San : Chat-GPT  --> 1:0
MichaelT
