Fusion API and Scripts
Got a new add-in to share? Need something specialized to be scripted? Ask questions or share what you’ve discovered with the community.
Switching From 'Manufacture' to 'Design view' back to 'Manufacture' Crashes fusion
2 REPLIES 2
enervino
141 Views, 2 Replies
Please have a look at the following simplified Python script for fusion, the part with the issue happens in
"MyExecuteHandler"
Basically, I'm trying to switch to Design view, draw something, then switch back to Manufacture to make a program including that new geometry, then generate a response.
Note: this will Crash Fusion!!
Run this script from the 'Manufacture' workspace.
import adsk.core
import adsk.fusion
import adsk.cam
import traceback
# Globals
_app: adsk.core.Application = adsk.core.Application.cast(None)
_ui: adsk.core.UserInterface = adsk.core.UserInterface.cast(None)
_design: adsk.core.Product = adsk.core.Product.cast(None)
handlers = []
# main Function
def run(context):
    try:
        global _app, _ui, _design
        _app = adsk.core.Application.get()
        _ui = _app.userInterface
        _design = _app.activeProduct
        myCmdDef = _ui.commandDefinitions.itemById(
            'SelectionEventsSample_Python')
        if myCmdDef is None:
            myCmdDef = _ui.commandDefinitions.addButtonDefinition(
                'SelectionEventsSample_Python', 'Selection Events Sample', '', '')
        # Connect to the command created event.
        onCommandCreated = MyCommandCreatedHandler()
        myCmdDef.commandCreated.add(onCommandCreated)
        handlers.append(onCommandCreated)
        # Execute the command.
        myCmdDef.execute()
        # prevent this module from being terminate when the script returns, because we are waiting for event handlers to fire
        adsk.autoTerminate(False)
    except:
        if _ui:
            _ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
# Event Handelers
class MyCommandCreatedHandler(adsk.core.CommandCreatedEventHandler):
    def __init__(self):
        super().__init__()
    def notify(self, args):
        try:
            cmd = args.command
            cmd.isExecutedWhenPreEmpted = False
            inputs = adsk.core.CommandInputs.cast(cmd.commandInputs)
            ######Create Events to handle inputs################################################################
            selectSectionLines = inputs.addSelectionInput(
                'SectionLines', 'Lines', 'Select Sketch Lines')
            selectSectionLines.addSelectionFilter(adsk.core.SelectionCommandInput.SketchLines)
            selectSectionLines.addSelectionFilter(adsk.core.SelectionCommandInput.Sketches)
            selectSectionLines.setSelectionLimits(0)
            # Connect to the command related events.
            onExecutePreview = MyCommandExecutePreviewHandler()
            cmd.executePreview.add(onExecutePreview)
            handlers.append(onExecutePreview)
            # on Cancel Button Press
            onDestroy = MyCommandDestroyHandler()
            cmd.destroy.add(onDestroy)
            handlers.append(onDestroy)
            # on OK button press
            onExecute = MyExecuteHandler()
            cmd.execute.add(onExecute)
            handlers.append(onExecute)
        except:
            if _ui:
class MyCommandExecutePreviewHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            pass
        except:
            if _ui:
class MyCommandDestroyHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            adsk.terminate()
        except:
            if _ui:
#gets run on ok click
class MyExecuteHandler(adsk.core.CommandEventHandler):
    def __init__(self):
        super().__init__()
        try:
            #be sure to start this in "Manufacture" to encounter the crash
            #if not crashing Run in "Design view" then "Manufacture"
            #With my testing this sort of switshing is possible when you run a script with no GUI
            #switch to Design view
            designWorkspace = _ui.workspaces.itemById("FusionSolidEnvironment")
            designWorkspace.activate()
            #draw some lines on a sketch
            #note you need to be in "Design view" to actually draw something it seems
            #Switch to Cam enviorment
            camWorkspace = _ui.workspaces.itemById("CAMEnvironment")
            camWorkspace.activate()
            #Put newly created lines into a program
            #generate program
            #note you need to be in "Manufacture" to generate progams
            #cam.generateAllToolpaths(True)
            adsk.terminate()
        except:
            if _ui:
2 REPLIES 2
kandennti
in reply to: enervino
Hi @enervino -San.
I tried it and it did indeed crash.
With the April update, it is now possible to access the root component of the design without leaving Manufacture.
I tried drawing a new sketch and drawing a line without going back to the design and it worked fine.
# Fusion360API Python script
import traceback
import adsk.core as core
import adsk.fusion as fusion
import adsk.cam as cam
def run(context):
    ui: core.UserInterface = None
    try:
        app: core.Application = core.Application.get()
        ui = app.userInterface
        app.documents.add(core.DocumentTypes.FusionDesignDocumentType)
        camObj: cam.CAM = get_cam_product()
        rootOcc: fusion.Occurrence = camObj.designRootOccurrence
        root: fusion.Component = rootOcc.component
        skt: fusion.Sketch = root.sketches.add(root.xYConstructionPlane)
        skt.sketchCurves.sketchLines.addByTwoPoints(
            core.Point3D.create(0,0,0),
            core.Point3D.create(1,1,1)
        ui.messageBox("Done")
    except:
        if ui:
def get_cam_product() -> cam.CAM:
    activete_cam_env()
    return app.activeProduct
def activete_cam_env() -> None:
    ui: core.UserInterface = app.userInterface
    camWS: core.Workspace = ui.workspaces.itemById('CAMEnvironment')
    camWS.activate()
enervino
That is the better way, I just could not get it to work the way you just did, keep on getting exceptions. Thanks!!
