Message 1 of 14
[bug] addByThreePoints method fails to create arc if the 3 points are too close
The code below crashes whereas the 3 points are disctinct. Setting the factor value f to 100 solves the issue.
The error message:
RuntimeError: 5 : Some input argument is invalid.
It seems that there is a problem with the precision of the numbers during the computation.
import adsk.core, traceback
p1 = [-0.00047752000000000005, 0.15192502000000002]
p2 = [-0.0006226001152828134, 0.15214303759958947]
p3 = [-0.0006731, 0.1524]
# The code works with f = 100
f = 1
def run(context):
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
product = app.activeProduct
rootComp = product.rootComponent
sketches = rootComp.sketches
sketchesPlane = rootComp.xYConstructionPlane
sketch = sketches.add(sketchesPlane)
arcs = sketch.sketchCurves.sketchArcs
pt1 = adsk.core.Point3D.create(p1[0]*f, p1[1]*f, 0.0)
pt2 = adsk.core.Point3D.create(p2[0]*f, p2[1]*f, 0.0)
pt3 = adsk.core.Point3D.create(p3[0]*f, p3[1]*f, 0.0)
arcs.addByThreePoints(pt1, pt2, pt3)
ui.messageBox('OK')
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
The issue occurs when trying to import a geometry from a file.
Here are all the triplets values that failed:
-0.00047752000000000005 0.15192502000000002 0.0
-0.0006226001152828134 0.15214303759958947 0.0
-0.0006731 0.1524 0.0
0.21081746 4.1827069 0.0
0.21083651 4.182706638774926 0.0
0.21085556 4.1827069 0.0
-0.0006731 6.05536 0.0
-0.00047595357441652345 6.055835953574417 0.0
0.0 6.0560331 0.0
0.07552690000000001 6.13156 0.0
0.07572404642558347 6.132035953574417 0.0
0.0762 6.1322331 0.0
0.22860000000000003 6.1322331 0.0
0.22907595357441654 6.132035953574417 0.0
0.2292731 6.13156 0.0
0.47744634 6.06242374 0.0
0.47746294213947027 6.062431160364481 0.0
0.4774793600000001 6.06243898 0.0
0.5225669000000001 6.13156 0.0
0.5227640464255835 6.132035953574417 0.0
0.52324 6.1322331 0.0
0.7518400000000001 6.1322331 0.0
0.7523159535744166 6.132035953574417 0.0
0.7525131 6.13156 0.0
2.32301542 6.10663498 0.0
2.3232331941927846 6.106781307383965 0.0
2.3234904000000003 6.1068331 0.0
2.8391104 6.1068331 0.0
2.8394962006423152 6.106711677988141 0.0
2.8397428600000003 6.10639114 0.0
3.22893182 6.13170732 0.0
3.2291685860022112 6.132085526306413 0.0
3.22958968 6.1322331 0.0
3.5775696800000003 6.1322331 0.0
3.578045633574417 6.132035953574417 0.0
3.5782427800000005 6.13156 0.0
3.58109266 6.11100124 0.0
3.5810981213636035 6.1109835689610295 0.0
3.5811028200000004 6.11096568 0.0
3.581097665305647 6.1109834386587565 0.0
3.7292965800000006 6.13156 0.0
3.729493726425584 6.132035953574417 0.0
3.72996968 6.1322331 0.0
3.9598600000000004 6.1322331 0.0
3.960335953574417 6.132035953574417 0.0
3.9605331000000006 6.13156 0.0
4.0284882600000005 6.0564141000000005 0.0
4.02893295481865 6.056200340963728 0.0
4.029113100000001 6.055741 0.0
4.029113100000001 0.1524 0.0
4.029061396913553 0.15214275684889197 0.0
4.02891498 0.15192502000000002 0.0
3.87651498 -0.00047498 0.0
3.8762972058072154 -0.0006213073839646991 0.0
3.87604 -0.0006731 0.0
3.7846 -0.0006731 0.0
3.784124046425583 -0.00047595357441670744 0.0
3.7839269 0.0 0.0
3.1401131000000007 0.0 0.0
3.1399159535744174 -0.0004759535744167994 0.0
3.13944 -0.0006731 0.0
2.9171773 -0.0006731 0.0
2.9168084710412754 -0.0005632027482395946 0.0
2.91656008 -0.00026924 0.0
2.7781173800000003 -0.00026924 0.0
2.777869005845322 -0.0005632285560581688 0.0
2.7775001599999998 -0.0006731 0.0
2.42062 -0.0006731 0.0
2.4201440464255835 -0.00047595357441661544 0.0
2.4199469000000002 0.0 0.0
1.6084931 0.0 0.0
1.6082959535744166 -0.00047595357441666136 0.0
1.60782 -0.0006731 0.0
1.1077092400000002 -0.0006731 0.0
1.1072699286841035 -0.0005096272777208597 0.0
1.10704376 -9.906e-05 0.0
0.70143624 -9.906e-05 0.0
0.7012100848537824 -0.0005096429720839872 0.0
0.70077076 -0.0006731 0.0
0.46099730000000005 -0.0006731 0.0
0.4606284711372198 -0.000563202601607623 0.0
0.4603800800000001 -0.00026924 0.0
0.32193738 -0.00026924 0.0
0.32168900584532195 -0.000563228556058086 0.0
0.32132016 -0.0006731 0.0
0.1524 -0.0006731 0.0
0.15214153574088737 -0.0006215323168355681 0.0
0.15192248 -0.00047498 0.0
Thank you
Jérôme Briot, Freelance engineer - Mechanical design and prototyping
3D Print Plus / Pro | IDF Import | GitHub To Fusion 360 | Tube Bending Data Exchanger | Slice Data Export
Memory Used | Basic Calculator | Check Computer Specifications | Import spline from any CSV file
