Revit to Formit workflow
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm new to Formit but have been using Revit and Sketchup a lot in the past. I'm hoping to figure out a good workflow between Revit and Formit so that we can hopefully move over more towards Formit at my office rather than Sketchup.
Here's my question - hopefully you might have some insight...
The project is in a concept phase which is why we want to test out different volume models. I have the project started in Revit already, with a defined project base point and a few defined levels. I also have a Sketchup-model in the exact same location in relation to the project basepoint - so the two models are interchangeable.
Now I want to take my Revit project and continue working on it in Formit! So how do I export my Revit project to Formit? I've downloaded the add-in, but it seems I can only convert family-files and not project files. I've built the current sketch both with walls/floors but also with masses, since I thought these might be easier to convert, but I haven't found a way to convert them. I've also converted the sketchup file to Formit but it was to heavy to import into Revit.
I would like to have a Formit file with simple masses from either Revit or Sketchup so that I have them positioned in relation to origo, and I want to keep my levels that I have already defined in Revit. I don't want to make new levels in Formit. Then ideally I would like to import or link the Formit file back into Revit so that I can update my plans/sections with real walls/floors etc. Is this possible? Or is Formit not intended to use this way?
I cant' for the life of me figure out how to work with coordinates and the placement of the project in relation to origo in Formit...
How would you go about working with a project at this stage in Formit..?
