Modify Array
Modify Array
Modify Array
Am I correct in assuming, once I have created an array, I cannot change the number of elements? I have come up short in my linear array, to fix this, I need to recreate the array or is there a better solution in this instance?
Thanks in advance for your help!
Tobias_Hathorn
You are correct - FormIt does not have that feature to 'update' a previous arrayed object (like in Revit).
There are parametric objects you can use in FormIt (via Dynamo scripts). Otherwise, you'll have to use Groups and manually copy them.
Here's a blog post with ALOT more information, as well as examples and samples of the Dynamo + FormIt workflow
https://formit.autodesk.com/blog/post/formit-360-dynamo-studio/
Tobias
Thanks for the info Tobias.
The link may need updating though, currently showing a 404 error.
Tobias_Hathorn
I see what happened with the link - there is an (invisible) space at the end of the URL in the message - if you copy and paste it into a browser it works.
Here it is without space
