Formit Application has stopped working
rajendra.deshpandehyd
I have installed FORMIT for Windows on windows 7 (64 bit).
When I launch the application, I am asked to sign in to A360.
After signing in to A360, it displays the message "Updating Licence" and the I get the error message
"Format Application has stopped working"
PLEASE SUGGEST THE SOLUTION.
The problem details are as below:
Problem signature:
Problem Event Name: BEX64
Application Name: FormIt.exe
Application Version: 16.3.242.0
Application Timestamp: 5abd42f1
Fault Module Name: StackHash_1dc2
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Offset: 0000000000000000
Exception Code: c0000005
Exception Data: 0000000000000008
OS Version: 6.1.7601.2.1.0.256.48
Locale ID: 1033
Additional Information 1: 1dc2
Additional Information 2: 1dc22fb1de37d348f27e54dbb5278e7d
Additional Information 3: eae3
Additional Information 4: eae36a4b5ffb27c9d33117f4125a75c2
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
tvollaro
I am sorry you are having trouble, here are a couple of follow up questions/suggestions:
  1. Please make sure your graphic(s) card drivers are up-to-date. Both drivers, if you are using a PC system with switchable graphics.
  2. Are you using a 4K monitor?
Tom Vollaro
Experience Design Architect - Autodesk
Thanks for the response.
Replies to your queries are as below:
1) The graphic card drivers are up-to-date.
2) Am not using switchable graphics, and
3) Am not using 4K Monitor.
One more I would like to bring to your notice is that, since Formit for
windows was not working, I installed Formit Extension for Revit and
surprisingly it is working. So problem is not with graphic hardware, it is
possible that Formit for Windows (offline) is not getting requisite
components while working offline. I am not a hardware man, so not so sure
about it, but that's the logical conclusion I could draw.
May be you can understand the problem better. Meanwhile I will contact DELL
and try investigating for the reason.
jeff_hauswirth
Meanwhile I will contact DELL and try investigating for the reason.
Check out this post about FormIt crashing with Dell backup running-
ADVISORY: Dell Backup + Recovery may cause application crash
Thanks for sharing all these information.
