If I use a Dynamo script in an .axm file and then export that file to Autodesk Docs, is the script embedded in the .axm and accessible to others that have access to the .axm in Autodesk Docs?
Solved by josh.goldstein. Go to Solution.
Yes!
Dynamo files are saved directly in the AXM, so anyone who downloads it can access and re-run (or even modify) the Dynamo script embedded there. They'd have to download the file and open it in FormIt for Windows for that functionality, however.
Yes!
