Hi mbeskowiney,
Thanks for the +1 on fixing mm input. We plan to address this in the next update.
Thanks also for mentioning the default unit issue. We plan to improve the consistency of this behavior next release as well. Can you share your preference for how this should be handled?
- Should FormIt default to the units used in the last file that was opened? (this happens already in FormIt for Windows with File > New, but not when the app is closed/reopened)
- If you open a file, then change the units, should FormIt default to the new units next time? (this happens already in FormIt for Windows with File > New, but not when the app is closed/reopened)
- Other nuances you feel strongly about?
Note that FormIt always respects the units setting saved in the file, so you could work around this for now by saving a blank file with the correct units set as a "template". Opening that file should remember the Units you set in the file.
Josh Goldstein
Senior Product Manager
