3D sketch (FormIt) in Revit does not launch FormIt
hliS658H
hliS658H
I have recently watched some tutorials on bringing Revit model into FormIt with 3D Sketch button under Massing & Site and want to try it. But it didn't launch the FormIt for me, and even if after I launced FormIt first, I didn't see the model being brought to FormIt.  Does anybody know what caused this possibly? I am using Revit 2022 and FormIt 2022. Thank you.
josh.goldstein
You'll definitely need to launch FormIt from Revit to see the model in FormIt. Launching FormIt separately won't enable a connection to Revit.
What happens when you click 3D Sketch in Revit? Any errors or messages?
Josh Goldstein
Senior Product Manager
hliS658H
No any error messages. Just nothing happened.
smilksh
Make sure you're in a 3D view and the "FormIt 3D Sketch" button is active (F is blue, not gray).
When the "FormIt 3D Sketch" button is clicked, you should receive the following dialog in Revit:
Do you see this dialog?
If so, which option are you selecting to Launch FormIt with?
hliS658H
I noticed that I couldn't bring FormIt model into Revit either, although I used to be able to do it.
I saw another thread with solution to the same problems, I am going to request our company IT administrator to try it.
https://forums.autodesk.com/t5/formit-forum/failed-to-import-formit-file/m-p/11376418#M4853
hliS658H
Yes, I did all that and I tried both options.
It might be something wrong with the system. I just found out I couldn't bring in FormIt either which I had no problem before.
smilksh
That does sound suspiciously like the issue you linked.
Hopefully the patch will fix your issues!
