Conceptual design stage needs consideration of street level views, particularly in European cities. While we can currently orbit down to street level, we need the ability to walk and adjust view position, with a Walk feature that follows terrain. WASD type controls would be ideal for navigation.
Solved by arne.bjelland. Go to Solution.
Hi!
Absolutely agree. We should have more options in how we can move and rotate the camera. You are able to "walk" around in your project by using the arrows up, down and sideways. I discovered that you need to first single-click on the screen to activate this functionality. If you press "shift" you will move fast.
I am not sure when we will add more camera functionality into the product but thank you for letting us know about the need. We have it on our todo list.
Regards.
Arne
Thanks Arne, I've clicked 'Accept Solution' as the arrow keys do work as you say (i missed the single click on the screen). It would be great to have the 'gravity' feature to stay on the terrain though, and also map the WASD keys, especially the Q and E keys for view elevation.
