Hi!
is it possible to include trees in the detailed wind analysis? I mean for example the trees that I find under “Vegetation -> tree line”.
Francesca
Solved by per.wessel.noreCT6K6. Go to Solution.
Hi!
Yes, these trees will be considered when you trigger a detailed analysis. The trees will be modeled in the wind simulation with a leaf area density to act as a tree, not a fully-blocking object.
Kind regards Per
Hello Per, Can you please elaborate on the density of the tree and how its calculated? Is there a certain density assigned to these trees, it will be really helpful if there is a documentation on the properties of the forma trees.
best,
Harish.
