I have been experimenting with Spacemaker, using it to import site information into Revit.
I have just gone into Forma, and downloaded the Revit plugin, and ran it. I don't see it in Revit. I still see the spacemaker plugin, but when I run it it tells me there is an update. Downloading gets me the same version I downloaded from Forma. "Continue without updating" cannot find any data. Is the plugin working for "Forma" yet?
Solved by kronz. Go to Solution.
Hey!
That is peculiar since the latest version for Forma is 0.8.2!
Could you try going into your Forma project, clicking three dots on the proposal -> Revit -> Download Revit plugin and see if that fixes your problem?
Also - a control question: Are you using Standard (New) or Classic version of Forma?
Hey!
Hi, thanks for the feedback!
The Forma addin will appear in the Massing and Site tab (the old Spacemaker addin appears in its own Spacemaker tab).
https://help.autodeskforma.com/en/articles/6984724-revit-interoperability
Thanks Zach!
I suspected it would not be the same Spacemaker plugin, I just didn't know where to look.
Thanks Zach!
