Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Revit Plugin
3 REPLIES 3
SteveFong
879 Views, 3 Replies
Revit Plugin
I have been experimenting with Spacemaker, using  it to import site information into Revit.
I have just gone into Forma, and downloaded the Revit plugin, and ran it.  I don't see it in Revit.  I still see the spacemaker plugin, but when I run it it tells me there is an update.  Downloading gets me the same version I downloaded from Forma.  "Continue without updating" cannot find any data.  Is the plugin working for "Forma" yet?
Tags (3)
Labels (3)
3 REPLIES 3
Hey!
That is peculiar since the latest version for Forma is 0.8.2!
Could you try going into your Forma project, clicking three dots on the proposal -> Revit -> Download Revit plugin and see if that fixes your problem?
Also - a control question: Are you using Standard (New) or Classic version of Forma?
kronz
in reply to: SteveFong
Hi, thanks for the feedback!
The Forma addin will appear in the Massing and Site tab (the old Spacemaker addin appears in its own Spacemaker tab).
https://help.autodeskforma.com/en/articles/6984724-revit-interoperability
SteveFong
in reply to: kronz
Thanks Zach!
I suspected it would not be the same Spacemaker plugin, I just didn't know where to look.
Forma Design Contest
Technology Administrators
