I started working with Forma today and in my excitement, I misspelled the hub name and would like to change it. Is there a way?
Solved by JasonArtley. Go to Solution.
Solved by arne.bassoe-eriksen. Go to Solution.
Hi @JasonArtley, we are looking into enabling you to do this yourself, but as of now you can contact us through chat inside the software (Help > Contact Support > Send us a message) and we can change the name of the Hub for you
same problem
Sending a message (Help > Contact Support > Send us a message) worked for me, the hub was renamed in less than a day.
One thing to note, the popup for "send us a message" doesn't work with the Opera browser. I had to switch to Edge for it to function.
Problem is solved
