Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Renaming a Hub
4 REPLIES 4
JasonArtley
695 Views, 4 Replies
Renaming a Hub
JasonArtley
I started working with Forma today and in my excitement, I misspelled the hub name and would like to change it. Is there a way?
Renaming a Hub
Labels (1)
  • Data
4 REPLIES 4
arne.bassoe-eriksen
Hi @JasonArtley, we are looking into enabling you to do this yourself, but as of now you can contact us through chat inside the software (Help > Contact Support > Send us a message) and we can change the name of the Hub for you
nruizendaal
in reply to: JasonArtley
nruizendaal
same problem
same problem
JasonArtley
in reply to: nruizendaal
JasonArtley
Sending a message (Help > Contact Support > Send us a message) worked for me, the hub was renamed in less than a day.
One thing to note, the popup for "send us a message" doesn't work with the Opera browser. I had to switch to Edge for it to function.
nruizendaal
Problem is solved
Problem is solved
