Hi there,
I have a large number of analysis areas and for each analysis I have to manually deselect all and select the one analysis area that I want to perform my analysis on.
Is there a way to deselect all analysis areas simultaneously and then select the wanted sites?
Thank you in advance! 🙂
Hi there,
Thanks for the feedback. We don't currently have a way to deselect all analysis areas simultaneously. I understand the workflow is cumbersome in this case, and are always interested to hear your ideas on how to improve it.
To better understand your use case, could you tell us what you are using the large amount of site limits (or zones) for?
Hilde
Hilde
Thank you for your answer.
I have a very large site that I need to run a noise analysis on. Since there is a maximum size for the analysis area I had to create multiple analysis areas and run them separately and later put them together.
I see! It would be very interesting to see how you do this, to understand how we could better support large site projects. I will contact you directly for more details.
Hilde
Hilde
