In my hub, I am not able to create a Project.
Fábio Sato
Solved by kasper.herlov. Go to Solution.
Happy to help figure this @fabiosato, sent you a private message asking for some more details so I can investigate 🙂
Hi @rjonesHHLL4 . Yesterday we had an issue with our re-direct function, so most likely you were in the wrong region, none of your fault. If you go to https://app.autodeskforma.com/workspaces now, you should be redirected to the region where your Hub is and be able to select it. Kindly let me know if this doesn't work you?
Thanks!
