Hi Forma Team,
I got this building data from the Library, but it shows as generic lines instead of building. And as I tried to export it to Rhino, they are not there anymore. Is there any way to turn generic lines into building and I wonder if that's the reason for the exporting problem?
Thank you in advance! 🙂
Can you share with us the link to the proposal? You can send it to us privately using the Help button bottom right of the Forma window, Contact us link.
Hi I have a similar issue, once I updated my building proposal from revit and back in forma the building is now in the layer generic but I cant turn it back into the layer building with the floor plans, etc, how can I change it? the process is (forma->Revit -> Forma (here is the issue)), thanks
At this time, we do not support floor plans on buildings that have been modified in Revit.
