When attempting to import a forma proposal into revit using the revit add-in, I received the following error:
Unable to commit revit transaction to store forma data. The forma elements have been loaded, but the bookkeeping information necessary to do an update later could not be stored. Update will be disabled in this file.
What causes this? Did we setup something incorrectly in forma?
Solved by greg_marr. Go to Solution.
@InnesNancy Can you contact us through the Forma in-product support so that we can get more information about your issue, and potentially link up with the error log in our internal error tracking system? Use Help button (bottom right) and then Send us a message.
Greg from Forma
Greg from Forma
