• Forums Home
  • Forma
  • Forma Forum
  • When importing multiple buildings from the proposal to Revit, levels should be filtered by elevation
Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
1 REPLY 1
daniel.gheorghe5GJK4
66 Views, 1 Reply
Right now forma will create a set of Revit levels for each building in the proposal. This should not be the behaviour. It should filter the levels by elevation and reference the elements to the same levels.
Labels (3)
1 REPLY 1
We used to have this as an option in the older version of the add-in, but we found that the vast majority of users created per-building levels.  From our discussions with users, this was primarily to keep the level areas as small as possible and to keep the buildings separate so that they could be manipulated separately.
Can you provide some more information on why you prefer to have your levels shared across buildings?  That would be helpful for future product direction.
Greg from Forma
