Find out how much solar panel energy your site can generate
marthe.brondbo
Alumni Alumni
Message 1 of 10
marthe.brondbo
One of the core capabilities of Spacemaker is offering you a range of analyses to assess the opportunities and risks for your project, and instantly act upon insights.
To help you assess the potential of your site for generating solar panel power, we’ve developed a new solar panel analysis.
Now available in beta for all Spacemaker users in the Analyze mode, it allows you to see the photovoltaic potential of your site. With a few input parameters, we use our sun analysis and local weather data to calculate the potential energy generation of roof-top solar arrays.
Read more about the analysis here and follow our in-product guidance to try it in action.
Let us know what you think!
Replies (9)
Message 2 of 10
clauspromisco
Community Visitor
Community Visitor
How much energy can solar panels generate on average?
Message 3 of 10
aimeeporeiuv48
The average solar system for a home consists of 20-25 panels. Still, the exact number you'll need depends on many factors, including where you live, how much energy you typically consume, and how much energy your panels can generate. Look at your energy bills from previous years to determine how much electricity you consume in all four seasons. You'll know how much solar energy you need to produce to cover your needs by getting that number. I'm glad I installed solar panels at home. They helped me save more money, and I bought them on the website https://www.dragonsbreathsolar.co.uk/product/diy-off-grid-solar-system-kits/. I was helped with a good choice here.
Message 4 of 10
ellis.herman
Thanks for asking! The energy generation of a panel will vary depending on the location, panel orientation, and shading, as well as the type of solar panel. For our solar panel analysis, we use a panel power of 150 W/m2.
Message 5 of 10
seda.tugutlu
Hello All,
I cannot see solar panel energy tool under analyses section.
I am sure I used it before, now it is unavailable.
Is there an update? or sth else?
Regards
Message 6 of 10
daniel.silva.gameiro
Hi @seda.tugutlu!
We have discovered some issues with the solar panel algorithm, so the analysis has been removed for now. However, we are working on launching it very soon in the Next-Gen project type.
I will ping you when the functionality is released.
Message 7 of 10
RyanCameron
We stick to general rules of thumb. For instance a 5ft x3ft panel will provide 400watts, spaced side by side and at least 18inches between rows.
However, this can change dramatically across different regions. Also keep in mind its most likely not possible to utilize the entire surface of the roof. We have roof hatches, vents, spacing of the panels themselves, mechanical equipment, etc... So you would want to provide a "grossing factor" of some kind when providing this number as it could be off by as much at 20-40%.
Additionally, what would be nice is to know what inside the building the estimated solar capacity can power. Telling me I have 1000sqft of rooftop solar potential doesn't really help me with the client. "Well, what does that power? The lights? the mechanical equipment?" Even just a ballpark is good enough. 1000sqft of rooftop solar, on the best day, could power X sqft of lighting for X numbers of rooms.
Otherwise, looking forward to seeing this out there soon! Cheers!
RB Cameron, AIA, LEED AP, EDAC
Digital Practice Leader
Message 8 of 10
solarpaneluk24
Community Visitor
Community Visitor
The average solar panel has a power output rating of 250 to 400 watts (W) and generates around 1.5 kilowatt-hours (kWh) of energy per day. Most homes can meet energy needs using 20 solar panels, which typically have an installed system capacity of six to eight kilowatts (kW).
Message 9 of 10
dawsonhaag19
Community Visitor
Community Visitor
Great to see technology advancing in this area! This new feature seems very useful. I’ve used similar tools to assess solar potential for my own setup and found them super helpful. For even more guidance, you might also want to consult a solar panel company like solar panels dublin. They’re professionals and can offer expert advice on maximizing your solar energy generation.
Message 10 of 10
powerhubdynamics
Community Visitor
Community Visitor
1. Online Solar Energy Calculators
There are several tools available to estimate solar potential based on your location:
  • Google Project Sunroof – Uses satellite imagery to assess roof potential (available in select areas).
  • NREL PVWatts Calculator – Estimates energy production based on system size, location, and weather data.
  • Solar Estimate (Solar-Estimate.org) – Provides cost estimates and energy savings projections.
2. Manual Calculation Using Solar Irradiance Data
If you prefer a more hands-on approach, you can calculate energy potential using this formula:
Energy Output=Solar Panel Capacity×Peak Sun Hours×Efficiency\text{Energy Output} = \text{Solar Panel Capacity} \times \text{Peak Sun Hours} \times \text{Efficiency}
Where:
  • Solar Panel Capacity = Total wattage of the panels installed
  • Peak Sun Hours = Average daily sunlight hours in your location
  • Efficiency = Panel efficiency (typically 15-22%)
3. GIS and Satellite Data for Solar Mapping
  • Global Solar Atlas (by World Bank) – Provides solar resource data globally.
  • Helioscope – A tool for designing solar projects with shading analysis.
  • PVGIS (Photovoltaic Geographical Information System) – Offers irradiation and energy yield estimates for specific locations.
4. Working with Local Solar Providers
Many solar installation companies offer free site assessments, using drone mapping, shade analysis, and historical weather data.
