Hi, in Autodesk Forma there is no possibility to import dxf. After downloading available data from Autodesk Forma- I have no site boundaries (property). The only way to solve that would be downloading dxf and I can't do it. Tried to export dxf to ifc but failed (Autodesk Forma failed to load it). Any suggestions?
Note: this post was revised after the rebranding from Spacemaker Next-gen to Autodesk Forma
Solved by krzysztof_jedrzejewskiAT8YZ. Go to Solution.
Hey!
As for nów we unfortunately do not support the .dxf import in Next Gen. We know it is important though and we are actively working on it making it available.
Out of curiosity- in which country / city is your project located? This information could help us to have a better data coverage in the future.
Hi, you may find this article helpful: Import of a map in coordinate system not supported by Forma
