Forma Forum
Welcome to the Forma Community. Give feedback, report bugs, and tell us your ideas about Autodesk Forma
Convert to terrain is grayed out. Help!
2 REPLIES 2
SDonovanBEH6R
425 Views, 2 Replies
SDonovanBEH6R
I imported an OBJ file. I'd like to convert it to terrain, but the option is grayed out in the library. I exported a sketchup file to an OBJ file and imported it into Forma. Any advice is welcome.
Tags (3)
Labels (2)
2 REPLIES 2
SDonovanBEH6R
Ok, I found a solution. When importing the obj file, you HAVE to make sure you select something for georeferencing.
jesper.staahl
I'm glad you found a workaround! That definitely sounds like something we could improve on. I'll make sure to log it in our feedback system! Thanks for reporting.
