Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Show only
Search instead for
You can only see Path, Comments, Description, Version, Markups and Issues on Reviews - It would be good to have custom attributes be added into the Review for Files.
The update attributes only shows up if you are a Key reviewer and started the review. This also asks you to input the information rather than just read only like description and version.
Adding a custom field like 'Document Title' to the review would be very useful. The Autodesk default Description field is not very useful because it can not be edited turned on or off or set as a required attribute so is often left blank. Being able to require Description or rename it to Document Title would also solve the problem. But just enabling custom attributes in the review area also give more options.
