A) Purpose
The purpose of this feature request is to establish a review process that is lean, efficient, and user-friendly—both to understand and to submit. Furthermore, by consolidating all documents to be reviewed and approved into a single stack within one module, the process becomes more streamlined and transparent. The review and approval workflow forms a core element of document management within a CAPEX project. Without the optimization of this process capex will lose much efficiencies.
B) Detailed description of the proposal
In the context of the ACC platform construction and plant management, all documents must undergo both a collaboration phase (markup process) and a formal approval process. To support this, an efficient and transparent workflow is required.
C) Today’s setup in ACC to get a document from review process to an approved document:
Within the remark process everyone can adjust and manipulate everyone’s markups or issues.
After review process is done all the markups will be incorporated in a new Version 2 document an updated in ACC on the same file stack as Version 1 .After the Upload of Version 2 is done all
the markups and the issue are still visible.
If you do not delete all markups and issues you need to publish the document to get an approved Version, otherwise you need to delete all the markup and close all issues on version 2.
To publish a document, it must first be submitted for publishing. During this step, the document is “transferred” into the Build module and stored as a file.
Current Challenges:
Within the review process, all markups and issues should be editable only by the reviewer who created them. No other reviewer should be able to modify or delete markups made by others. Once the workflow has been finalized, all markups and issues must be locked to ensure that no further changes can be made, not even by the original author.
After the review process is completed, all notations will be incorporated into a new Version 2, which will be uploaded to the same file stack as Version 1. The markups and issues from the previous version are not copied or inherited into Version 2. Instead, the approver can compare the two versions by using the change comparison functionality within the ACC tool.
As the last uploaded Version shows the approved document there is not need of publishing or to delete, close any remarks or issues.
This idea of the new workflow setup should enable:
General Requirements
The rough requirements for the single objects are described as below:
1 | Reviewer should edit only their own comments | must |
2 | Reviewer should not allowed to change their comments After review Workflow is finalized | must |
3 | Reviewer should be addable , deletable, modifiable | must |
| ff |
1 | Attributes should be set, change, deleted during the workflow steps , especially at the end | must |
2 | Attributes should be customizable | must |
| sub. |
1 | Markups should be not copied from old version to new version (should not be inherited) | must |
2 | Documents need to be stored on the same stack as they original have been stored (Visibility only the newest is seen, but file historical can be visssible) | must |
3 | Cover page, once document is successfully approved a coversheet should be as a “first or last” page added to the original document. The cover page shows Workflow specific data and reviewer / approver data, Name and electronical signature | must |
4 | Workflow comments, not on document (e.g. not markups) if rejected or general comments needed on workflow level | must |
5 | Workflow comments on document level (e.g. not markups) if on a document level comments needed – one document is approved another rejected | Optional |
6 | Documents to be stored in one place - “Single Source of truth | Must |
7 | Versioning available | must |
8 | “Stamps” , “signes “after approval to be on reviewed document | after |
| sub. |
General
1 | Review should see there personal work task out of workflows Independent if a “Role” is linked to a workflow or | must |
2 | Delegation if someone is out of office | Optional |
3 | Each Document need to be traceability. E.g. Who was within the approver process , who signed when | must |
4 | Overall WF list within a project with all the different information should be exportable for reporting and tracking purpose | must |
5 | File report : all Files & metadate& Folder & subfolder . download in “Excel” | must |
| sub. |
TX to all who supported me getting this request together , Michael
