It would be good if, when the layout of a plan changes, the markings are also moved accordingly. For example, if the floor plan and the section are swapped on a plan, the previous markings should also be moved. This prevents any confusion when plans are moved. This applies in particular to PDF and DWG files, as well as plans in Revit files that are stored in Docs and compared with each other through version control.
