Description
Resize callout text boxes
Moving around a callout textbox is difficult, as you have to move the arrow and the “leg” instead of just moving the text where you would like
You can copy and paste, but it only pastes a singular time, so you have to continue going back to copy an item.
Highlight text function does not work well on pdfs.
SUBMITTALS: Signature option instead of stamp.
SUBMITTALS: When you upload stamp image, image should stay in system so it can be used in the future versus uploading a stamp every document
Add “Count” and measurement features.
Be able to add an outline box around text
Be able to thin or thicken the outline and/or arrow on Callout and regular Text features.
It would be extremely helpful to be able to set up your defaults for the mark up tools. For example, if you want to make all your comments blue, you have to change the color every single time you make a mark up instead of just having it saved.
Business Case
Better markup-tool functionality will help people stay inside ACC instead of exporting/downloading to use 3rd party markup tools. Doing multiple markups in ACC for submittals is just too time consuming and doesn’t always work. Continuity = saves time.
