Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Improving UI for "Push to Autodesk Docs"
When pushing drawings to Autodesk Docs, there are three UI issues observed.
1. The selection list shows all projects I have access to. It's hard to find the correct folder!
-> They are not in (alphabetical) order.
-> It should show only folders that I have selected in the Desktop Connector.
2. The folder with naming standards is missing the icon to show it has naming standards.
3. Fields for fixing names are too small to show the name to be fixed.
-> The fields have the exact size of the defined standard. I the standard is defined by X-X-X, there are three fields that allow one character/number only.
-> While the fields have technically the correct size, the existing name is truncated. It's difficult to read it and make corrections based on the existing name.
Expected Result:
1. Only cloud projects are listed that are selected in the Desktop Connector. They are sorted in alphabetical order.
2. The folder with the naming standard shows the same icon as in the cloud.
3. The fields scale dynamically, so that the (wrong) full filename can be read. Idea: Green border of the field if the naming standard is met, red border if corrections are needed. The naming standard should be shown as defined in the cloud.
