Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Implement the functionality to create folder shortcuts within other folders in ACC-DOCS
In our project, we have a folder structure that includes various contracts and a central management folder for all contracts. In the contract management folder, we need to have links (shortcuts) to all the specific contract folders. This will facilitate quick and organized access to documents related to each contract.
Example of Folders Structure:
00-Management
-----01-Letters
----------01-Contract01
---------------01-Letters
--------------------01-Letters(Shortcut)
--------------------(Other management files)
----------02-Contract02
---------------02-Letters
-----02-Logs
---------------01-Logs
--------------------01-Logs(Shortcut)
---------------02-Logs
-----03-Engineering
---------------01-Concrete
--------------------01-Concrete(Shortcut)
---------------02-Mechanical
--------------------01-Mechanical(Shortcut)
---------------02-Concrete
02-Contract01
-----01-Letters
----------(contract files to be referenced)
-----02-Logs
-----03-Engineering
---------------(contract files to be referenced)
03-Contract02
-----01-Letters
-----02-Logs
-----03-Engineering
Adding this folder shortcut functionality will significantly improve efficiency and organization in contract management, giving facilitates direct access to contract folders from the management folder, keeping the file structure organized and easing to navigate and reduces the time spent searching for specific contract documents.
18 Comments
marikamKYVFX
Please, it is absolutely essential for large projects to have shortcuts to other folders that contain relevant data.  Many files are relevant to more than one category or main folder, so shortcuts are essential to navigate to the correct place.
francisco.fondaJGAAN
Exactly! we are studding some alternatives to this. If I know some way I´ll tell you.
jessica_amaralQH3W5
That would be incredible for the project I'm working on! It would reduce a lot of work time.
wendel_pedrosoSV4MH
Community Visitor
Gilmar.Xavier
Fantastic idea @francisco.fondaJGAAN
maria.celestino
Good idea !
daisyN37QZ
Modern information-management practice is built around the idea of a Single Source of Truth. International standards such as ISO 9001 require every controlled document to carry a unique identifier and be maintained in only one authoritative location. When people need that document elsewhere—for example inside an individual project area—the accepted remedy is to surface it through a stable hyperlink, not a duplicate file. Microsoft’s SharePoint Online, for instance, lets you click Copy link; the resulting URL always opens the current version of the item even after it is renamed or moved. Similar mechanisms exist in every mainstream document-management platform, which is why auditors treat “one copy plus links” as normal good practice.
Without folder-link capability, teams are forced to upload the same document into multiple Autodesk workspaces. That breaks the Single Source of Truth rule, creates version conflicts, and triggers nonconformances during ISO or client audits. It also wastes user time: someone must hunt down each stray copy every time the master file changes – which never happens btw, no one has time to control this. Conversely, if Autodesk Docs could store a “link object” that points to the master, then:
  • Everyone sees the latest revision automatically.
  • Permissions flow from the master, so one permission change secures every reference.
  • There is just one identifier per document, satisfying ISO 9001 clause 7.5 requirements.
  • Help-desk calls and re-work caused by “wrong version” mistakes drop sharply.
Competitive Snapshot – Ten Platforms That Already Offer Stable Folder or File Links
  • Microsoft SharePoint Online – “Copy link” produces a URL that always opens the latest version
  • Box Business – Renaming or moving a file does not break its shared link
  • Dropbox Business – Re-uploading a file as a new version keeps the existing shared link intact
  • Google Drive / Workspace – “Manage versions” lets you replace the file while the link stays the same
  • OpenText Content Suite – Every object carries a permanent node-ID that external systems reference
  • IBM FileNet Content Manager – Objects are addressed by unique, sequential IDs designed for stable linking
  • Egnyte – Users can promote a new revision while existing links continue to show the current file
  • M-Files – The platform exposes a “Get Web URL” command for any object or view, and links survive client upgrades
  • DocuWare – URL integrations rely on a GUID that identifies the record independent of its storage location
  • Laserfiche – You can create URLs that point directly to documents or folders; the link always opens the entry in Web Client or Mobile
Enterprise buyers compare feature lists. If Autodesk lacks a capability that all ten widely used rivals provide, evaluators conclude that Docs/Build is not yet “enterprise-grade” and may down-select it early in an RFP process.
Risks of Leaving the Gap Unresolved
Audit exposure: Duplicate files violate ISO control principles and will be cited as non-conformances.
Operational errors: Teams may act on an outdated policy or drawing, leading to re-work, warranty claims or safety incidents.
Adoption leakage: Users will keep sensitive corporate documents in SharePoint, Box or Google rather than move them into Docs, reducing Autodesk seat utilisation.
Lost revenue: Feature gaps visible in competitive matrices reduce short-lists and ultimately market share.
Perception: Absence of linking implies Autodesk does not fully understand established information-management doctrine, which can harm brand credibility among regulated industries.
Implementation Considerations
A practical design is to store a tiny “link” object that points to the internal ID of the target folder or file. The link should inherit the target’s permissions automatically and display a chain-link icon, so users know they are looking at a reference, not the master. The API must expose endpoints so administrators can script link creation when spinning up new projects, and a reporting tool should flag duplicate files that could be converted into links.
Recommendation
Add folder- and file-link functionality to Autodesk Docs & Build in the next major release cycle. Doing so aligns the platform with ISO expectations, closes a conspicuous competitive gap, and spares customers the cost and risk of uncontrolled duplicates.
Conclusion
“Send links, not copies” has become the universal rule for controlled documents. Every leading content-management system already supports it; auditors demand it; users expect it. Implementing folder-link capability will bring Autodesk Docs into line with global best practice and strengthen its position as a serious, compliant solution for enterprise information management.
Renata_Rogic01
There is an option scan duplicates in files. We use the same document name and overwrite it for every new revision, so only latest revision is saved under this document name, and entre revision history is saved under version attribute.
daisyN37QZ
Scan duplicates is a helpful option - but it doesn't solve the problem. The duplicates should not be there in the first place and they would not be there if there was an option to add a link. Uploading douments from other systems into Autodesk docs is bad practice for the reason cited in my original post. The documents should be referenced in Autodesk docs/Build with a link which ensures that only the latest version is available.
Corporate level documents such as policies are not under the control of project teams, and are created, controlled and reviewed by other departments. A link is the perfect way to view them and will not go out of date.
Please priorise this feature. Very important
azadeh_parsaeiLBUU4
It would be very helpful if ACC had an option to link a document from one folder to another. In our project files, we often need the same document to appear in two folders — for example, one as a received document from the client and another in the approved documents folder for sharing with users. This would help avoid duplicate files and make version management much easier.
n_vothuy
There is no way to ensure that version control tracks through all folders; i.e. once a new version of a certain document is uploaded in one folder, other folders where copies may be stored will not automatically get the new version. So if different stakeholders have access to different folders, they may be looking at different versions of a document. The copied files should be “links” to the original version one [email protected]
Tags (3)
swotton8FJDD
To simplify document control, it would be helpful to be able to keep the most up-to-date copy of a file (drawing or otherwise) in one place, and put a links in other folders rather than copying the file. Currently we're having to create multiple versions of the same file and this makes document control administratively burdensome.
In our ideal scenario, we receive a file from a sub/supplier and file it for record in folder1. For the use of our field team, we'd create a link in folder2 that points back to the original file in folder1. People who have access to folder2 can see and access the file, but the one true copy of the file lives in folder1. when the original file is updated, links update automatically and the new version is reflected in folder2.
This is similar to how symbolic links (symlinks) function in windows, macOS, and linux.
r.farnham
Over a year later, and sadly it doesn't seem that this functionality exists yet.  This seems like important basic functionality for a document storage system.  Please prioritize this!
trygve_hauglandQCMU4
Community Visitor
On my computer, I am able to create a shortcut folder that links two folders together. I am suggesting to implement a similar functionality in ACC as well. In one folder you can access a different folder, with a different location and path, with the shortcut
We share the same issue.
With the image below, the requested feature has already been implemented on another platform.
jonminick
Duplicate ideas were merged into this one. Their votes and comments now count here, so please keep voting on this idea.
jonminick
