Welcome to Forma for Construction Ideas! View the Forma for Construction Product Roadmap here. Top-voted ideas may be considered for future development. Learn more about the feedback process here.
Forms - unassign users
Currently if you assign (accidentally or on purpose) you are not able to unassign a form. The solution is to archive the current for and start over.
Please add the ability to clear out or remove the "assigned to" field for forms or the option to deactivate that field entirely.
1 Comment
buildintel
@ianderson_arkance
I’m trying to understand the workflow gap here. If the form is Closed, the assignment usually becomes a historical record - feel free to ignore.
If it’s Open, the platform requires an Assignee (Person or Company) to ensure accountability for the data entry.
Are you looking to 'Clear' the field to reset the form to a draft state, or is the goal to remove it from someone’s 'To-Do' list without archiving it?
Usually, if a form was created in error, Archiving is the intended path to keep the audit trail clean, or then you can also Discard.
